Are we Flying this weekend??? ( SUN )
Postby Fast Eddy » Sat Mar 11, 2006 6:28 pm
Wow
What a storm we have had. It looks like Mayyyybeeeee possibly we will have a shot at flying sunday. The worse thing is the cold air up high. with moderate winds 10 to 15MPH..
The forcast is for 260 winds on sunday and minus 5C at 6K. 55 degrees for tomorrow hig in S B which has been lowered by 5 degrees from previous runs. I still believe that temp is a bit high as a whole. Low cloud base early on and it should rise a bit through the day. depending on how fast the air mass dries out... I wouldn't expect bases higher than 4K at all. Might have to launch lower launches I/E By Pass...
The road to take off will be packed with spectators etc with the low snow levels. So who is game to go FREEZE your but off and test the deIcing gear on your wing???
I am available for crew...
Ed S
Contact
You should all have it
Fast Eddy
