1/15 Wed / Nuthouse / Topa Bluffs / Carp / 9200
Postby sd » Tue Jan 14, 2014 4:33 pm
Link to Sundowners flight log for Wednesday
http://paraglide.net/log/14/01-15/1_nuthouse_bluffs_carp.htm
Nuthouse to the Topa Bluffs to Carpinteria / 9200 Feet
___________________
Tuesday Night Update
Aaron and Andy are on board. I'll meet Aaron in Carp at 9, then Andy at Nordhoff at 9:30.
____________________
Tuesday Afternoon Troll
Anyone up for the Nuthouse Wednesday? The lapse rate may be slightly better on Thursday, but there is less wind forecasted above 6K for Wednesday. I suspect we should be getting to 7 or 8 K going over Casitas Pass. The wind aloft drops again on Friday, but the lapse rate and max altitudes may be fading. Still ok on Friday, but trending toward the end of the cycle. Should be good in SB everyday at least through the end of the work week with west down low and east up high. Cooling down over the weekend.
I won't likely fly unless someone wants to play hookie and suffer on the Nuthouse climb with me.
Re: 1/15 Nuthouse Wednesday
Postby Dainsberg_Andrew » Wed Jan 15, 2014 7:55 pm
,,, there i was- over nuthouse ridge when Condor68 came in from the NW being dogged by 2 crows.. ive been lucky enough to fly w/ condors a few times- it truly does seem that (contrary to other soaring birds) if they see us they often come over to fly along... 68 flew directly at me from about 3/4 mile away and as he neared, the crows dropped off. a pal and a bodyguard, we flew almost wingtip-wingtip in a lazy thermal- close enough for eye contact- . eventually, i was outclimbed and 68 went on glide over to spine one. i followed, lower, but never caught up. i got up to around 5k @ pyramid and nord ridge. There was strong NE around my alt/location and I decided to bail to the HS in an abundance of caution i suppose; out of the mtns my ground speed was 30-35mph for awhile. tom pushed Ebound then Wbound and maxd the day in his typically amazing way... Fun trip w/u guys. /
ps, info from a biologist friend: "A little background on your friend. HE is condor number 568 (the tag only gives the last 2 digits. The color of the tag indicates the first number. e.i. black tag = 500s). He was born 28 April 2010 in the zoo, and released into the wild in 2011. Seems like he's got the hang of things ay.
They are very curious birds, so I'm not at all surprised that they come in for a closer look at you.
Oh, and those were ravens harassing him. Ravens are notorious for being little buggers. Always harassing the bigger birds (eagles, red-tails), even though the condors pose no threat to them. Part of it is a game to them. I've seen a condor perched peacefully in a tree. Then 2 ravens will show up, perch near him, and hop closer and closer, then one will sneak in and pull one of the condors feathers. It's like the other one is daring him to get a condor feather. Maybe it's a right of passage."
Dainsberg_Andrew
Comments ?
Postby bump » Sat Jan 18, 2014 2:19 am
:shock: :idea: :?: :wink:
bump
