Nuthouse Sun
Nuthouse Sun
Postby Chris G » Sat Dec 10, 2011 9:22 pm
Eyeing the Nuthouse for Sunday since SB has been pretty weak the last few days. Winds are switching West which should help push us downrange. 10 AM at Nordhoff HS. I'll double check and confirm conditions in the AM.
805 368-3543
Re: Nuthouse Sun
Postby Chris G » Sun Dec 11, 2011 8:51 am
Cumis forming East of White Ledge, with a stellar 27º spread up to the inversion at 5k. Nordhoff HS at 10!
Re: Nuthouse Sun
Postby Chris G » Sun Dec 11, 2011 2:32 pm
Ahhhhh-sum! Alexei G met me at the HS and we were on the trail by 10:30. We already had clouds popping to the West and a few wisps were starting to form over the NH ridge. I was a little concerned about the moisture coming up from Ventura and shutting us down but cycles were good on launch, if a little long between big ones. Alexei was off first in a perfect cycle and he nearly hit ridge level straight up from launch. This was his first flight at the NH so he didn't get to experience the scratch-fest. He was transitioning to Pyramid by the time I got off in shadier cycles but the climb was still relatively easy. We could tell it was going to be a bit edgy but lift was plentiful and by now we had nearly solid 4200ft cloud base all the way across Nordhoff. We had a definite East aloft with West lower which made transitioning to Stooges and Twin peaks tricky but lift upon arrival was fat and predictable and cloud base over Chief's was closer to 5k. We made one pass up the spine before Alexei opted for heading back to the HS. Fillmore looked doable but I wasn't keen on pushing East solo so we took the glide home.
The air was definitely textured to an extreme but the prospect of cloud base made it worthwhile. Base got considerably higher the further East you went and texture seemed to mellow some as well. At Chief launch level it was really pleasant.
Re: Nuthouse Sun
Postby Marty DeVietti » Sun Dec 11, 2011 2:57 pm
Wow, glad to hear you guys got some sweet pre-frontal action. Thanks for posting.
Marty DeVietti
Re: Nuthouse Sun
Postby Dizzy » Sun Dec 11, 2011 3:59 pm
Fun day. Here is my track:
http://www.paraglidingforum.com/leonardo/flight/535846
I will post video later.
Alex
Dizzy
Re: Nuthouse Sun
Postby Dizzy » Wed Dec 14, 2011 2:31 pm
Here is a short video from the flight:
http://www.youtube.com/watch?v=C8ltgGXGKgI
Dizzy
Re: Nuthouse Sun
Postby Chris G » Wed Dec 14, 2011 6:08 pm
Awesome! Nice vid! That was such a fun day!
Users browsing this forum: Bing [Bot] and 9 guests
