Tuesday Synopsis
Tuesday Synopsis
Postby sd » Mon Nov 29, 2010 9:43 am
Tuesday Morning, 830. Probably should have taken a shot on Monday. The lapse rate faded faster than expected, and I'm looking at variable high clouds. The wind is down, so it will likely be marginally soarable, but without crew on a weekday, I need to pass and wait for the weekend. Tomorrow doesn't look any better today.
Monday Morning look at the Tuesday.
Hoping to make room for a flight on Tuesday. Meet time at Parma dependant on conditions Tuesday morning. Expect 9:45 to 10:45 at Parma to maximized the day, but it should work good later for local flights to the beach.
Looks like good flying weather all week. Monday appears to be robust with some left over wind in the morning, but expect it to block by midday as high pressure builds and the upper flow clocks around from the NW to flow from the NE. Expecting a Santa Anna event across the Oxnard Plain on Tuesday, but Santa Barbara should be sheltered and the upper level winds are backing down to light and variable through our max altitudes. Tuesday's lower level lapse rate looks ok, but not ballistic, about 20 - 25 degrees F between the surface and 6K.
Continued warming through Thursday, but the high pressure moves off later in the week with returning potential for instability by Friday.
