Posted for Hammer Re:His Record Breaking 190 flight
Postby Marge » Tue Sep 22, 2009 8:49 am
:D :D :D A Saturday in The Sky :D :D :D
The cast:
Fast Eddie - driver extraordinaire – He’s pro in everyway. His knowledge of the sky, the clouds, the terrain and how it all relates to the flying day is incredible. He studies the areas and knows all the ins and outs so there’s never a question regarding retrieve. Retrieve will arrive and arrive as quickly as possible. They don’t call him “Fast Eddie” for nothing.
Tony Deleo a.k.a. “EL DIABLO” – The ultimate mileage junky. It’s all about going and going as far as humanly possible. He’s the man and it’s important to listen to his knowledge.
Bob “YNA”– The guy that always appears so disorganized and never seems to have his shit together but he always pulls off some kind of great flight. His hang glider has parts that have been changed, moved and even removed. His wing has been stitched here and glued there or maybe that was duck tape (does he own 3M stock?). It seems that Bob was shanghaied by Captain Morgan and crew. He looked a strange color of green on the way up the hill which put him at a distinct disadvantage.
And then there’s me- Robert (HHShark) Millington or just Hammer – My friends know that I am very much the retentive type. That certainly wasn’t the case on this day. The only thing I did right was, listen to Tony and wear the right coat
First, I didn’t bring my O2. “We’ll never get that high, it’s not that kind of day” and of course, I punch off and immediately climb up to 14 grand. Oops! After the initial climb out I realize the valve from my camel back is hanging behind me and there is no way for me to reach it. Good thing I had six lbs of water that I couldn’t drink on this 6-hour flight. Oops. Again?!!
Not only that but my PTT had fallen in the dirt while I was setting up and I didn’t bring my spare. It didn’t seem to be a problem, since it worked fine during my flight check. But as is the case with PTTs, it got stuck and I was keying and not aware of it for quit a while. I later learned that I did a total head-trip on Bob A. (YNA) and I have the same vario. My keyed radio and vairo sounds along with Bob’s previously mentioned condition had him quite confused. There he is turning in what he thought was killer lift and ended up being major sink because the sweet vario sounds he was hearing telling him he was in this great lift was really coming from my vario through my keyed PTT. So much for the guy with the hangover getting a break.
The Flight
Details available at http://www.paraglidingforum.com/leonardo/flight/271550
The first challenge with any flight from Pine is to get high enough to go over the back. You normally need to get at least 1000’ or 2000’ over launch to go over the back but you always want more. With launch at 7000’, going over at 8000’ or 9000’ and not getting anything more, is just enough to get you deep into the badlands, which is very uncomfortable. At the very least it leads to a lot of work and at worst a premature landing. Diablo and I climbed to 14k above launch which made the “badlands” a moot point. Bob A. bounced around at 500 over for a while then climbed to 8900’, flew the ridge East to Reyes peak then beamed out to 13k.
Once over the back, the next point to make is Guillermo, which is at the western edge of Lockwood Valley. From Guillermo, the next point is Frazier Mountain, which is only about 20 something miles out on course. Basically, if you can get to Guillermo you can get to Frasier. It’s after Frazier that the challenge begins. We all bee-lined to Guillermo, then Frazier only stopping at those two points.
The hardest part about getting miles from Pine Mountain is traversing the first 20 – 30 miles of the Antelope Valley. It’s here, after leaving Frazier Mountain, that you really need to be very aware, lucky, and in my case have Diablo out in front telling you where the convergence line is. This is the area of California that is tied up in a knot geologically speaking. Because of all this very active terrain meeting here the orographic effect on the atmosphere is immense. There can be great convergence but you have to be able to read valley flows, clouds (if they exist) and the terrain carefully to find the convergence seams. This day we had some clouds marking the lift and Tony would just see the cloud and just go to it. The ATOS is so fast all I could do was try to follow.
I was able to connect with a convergence line off the Liebre Mountains because of my knowledge, my ability to read the sky, years of experience, great skill, and because Tony came on the radio and said, “Hey dummy, there’s a great convergence lift line forming off the Liebre Mountains.” I think I’ll go there! Duh!
After making the connection through the Liebre Mountains, the next part of the journey from Neenach to Helendale was pretty scrappy for me. It’s a stretch of about 70 miles and I spent most of the time struggling low and scooping thermals off the deck. And then I heard “him”, the voice of “EL DIABLO”, announcing his location and altitude. As I was struggling, I could hear Diablo reporting his position and learned that the distance between us continued to increase and his altitude was always much higher than mine. I was being left in the dust and getting more and more frustrated.
Just as my frustration was at an all time high for the flight, once again the voice of El DIABLO announces: “It gets much better the closer you get to Helendale.” And as is always the case with El DIABLO, he was right. Once in Helndale, I managed to climb back to 13 and change and head off towards the Ord Mountains away from roads. Being the timid pilot that I tend to be, I didn’t go as deep into the Ords as El DIABLO. A safe place to land just looked too far away from that line. Since I had such poor communication with my PPT not working well at all by this time, I thought he said we were going to follow the I-40 but it was really the I-15 we were going to follow. I was heading down the I-40 when I again hear El DIABLO and learn that I needed to change coarse as he was heading down the I-15 and not the I-40. It took me a long time to recover from that mistake. My tail was stuck firmly between my legs and I was running for safety. Then El DIABLO must have sensed this and the radio came to life, “Follow the Clouds Young Man: Stay with the Clouds.” So I trusted these words of wisdom from the master and of course this worked!
Well, it worked till a point. Due to PPT issues and lack of understanding of terrain, I finally threw in the towel and turned off course line, which was a very intimidating. I was heading toward Baker Valley to look for a road to land by. Low and behold coming into the southern end of Baker Valley I see what appears to be a road that I could land by but realize it’s not a road but a dike and there are no roads to be found. I think about the 10-mile walk ahead of me if I don’t make Baker. Fortunately, I made it.
Knowing Tony as I do, I knew he would be flying for many more hours and I could be waiting in No-Mans land for a very long, long time. I wanted to make the town of Baker so I could at least wait in comfort, with A/C and a cold drink at the Bun Boy or the Mad Greeks. I landed at the Baker airport and didn’t even have time to get my harness off when Eddie and Bob showed up and I was saved. It was a cool 102 out, and the sun was starting to set.
We ended the day by driving out to 233-mile mark and picking up El DIABLO at Prim in Nevada, not far from Las Vegas.
The record
- A few years back Tony and I flew to Furnace Creek in Death Valley and set a new record of 186 miles for
both rigid and flex wings.
- Last year Tony flew 225 from Pine setting a new rigid wing record.
- Today Tony and I broke our own records by a tiny amount.
- Rigid wing old record 225, new record 233 by Tony (counting dog leg, Searchlight to Prim 253)
- Flex wing old record 186, new record 190 by me (counting dog leg, wilderness back to Baker 205)
Tony is always very generous and is willing and eager to share his knowledge with any pilot who is interested. You don’t have to want to fly 233 miles but every pilot would benefit from his extensive knowledge if they were going to fly cross-country. Take advantage of this unique opportunity and the next time Tony posts he’s flying, go along for the ride. Be prepared for a long day that you won’t regret.
The details:
190 Miles in 6hr, 6min, 56 sec
Max Altitude 14,200, Max climb 1892, Max sink 1344, Max air speed 45, Avg. MPH 31.6
Nice tail wind!!! :D
hammer record-1.igc.alt_2.png (2.6 KiB) Viewed 28132 times
hammer record-1.igc.speed_2.png (3.56 KiB) Viewed 28132 times
hammer record-1.igc.takeoff_distance_2.png (1.87 KiB) Viewed 28132 times
hammer record-1.igc.vario_2.png (3.36 KiB) Viewed 28132 times
A great day of flying in the mountain...$60 in gas.
Not driving your fellow pilots crazy by keying your mic...$80 for a new PTT
Being able to fly 190 miles in 6 hours 7 minutes, 32 seconds and pimping off Diablo...Priceless
(You wouldn’t be reading this but for the great help of Marge and YNA. Thanks!)
Re: Posted for Hammer Re:His Record Breaking 190 flight
Postby redfly » Tue Sep 22, 2009 9:57 am
brilliant write-up hammer - thanks for sharing!
and of course CONGRATULATIONS!
Jonas
jonas at buchli dot org
redfly
Postby Tony Deleo » Tue Sep 22, 2009 5:35 pm
I am really impressed! All the graphs and charts! Great right up :D
Tony Deleo
Postby Tony Deleo » Tue Sep 22, 2009 8:30 pm
Saturday’s Flight to Primm, NV.
I had spent the past couple of weeks visualizing the flight to Primm. I looked at as 2 flights: the one from Pine Mnt. to The Ords and then the Ords up Highway 15 to Nevada. As usual I had been watching the weather for days and Saturday did not hold any obvious great potential other than there was going to be west wind. The forecast called for tops in the 11-12k range at Pine and there were wind warnings in the Antelope Valley for gusts to 33 mph. Robert and I had discussed this and decided to go flying anyway. On the way up the hill, and with Cougie having withdrawals we resigned ourselves to enjoy whatever the conditions were. There was a good lapse rate going up the hill with the wind blowing lightly out of the north. At takeoff there were nice cycles out of the south. We had agreed to takeoff at the same time due to the potential of high winds in The Antelope Valley. As Robert and I setup I saw the rear door of my truck open, as I went to shut the door there was Cougie face down in the back seat. I think I had more fun giving Cougie a hard time than I did flying that day-of course I had never been in that condition myself! At 11:30 Dracula got out of his coffin and started to set his glider up. At 12:00 I asked Robert “it looks good so where are the clouds”. Robert took off and went to the knob to the left of takeoff and slowly climbing in the first bowl. I took off and headed to the 2nd bowl and right into a “boomer”. Robert and I were climbing out with a drift from the southwest as there were clouds forming above us and in Lockwood Valle. Robert was a 1000’ and went on glide first. I was headed for the clouds on the south side of Lockwood Valley. I headed for Frazier and reached it just as the lift cycle had passed. Fishing around the west end of Frazier and not locating anything substantial I went on glide leaving the towers with 12,500’. There were clouds forming over Highway 5 to the south but I was apprehensive about going there feeling that I would have to fly upwind to The Libres. Fortunately for me small clouds were forming there. Robert and announced that he was leaving Frazier with 14K. To optimize my glide I put on 30 degrees flaps which is minimum seek and let the northwest wind take me to the shear line on The Libres where I climbed to 11k or so in a 18 mph southeast wind. At this point there was a cloud forming near south of Fairmont Butte. I opted to go on glide to the clouds forming at Rosamond. Arriving At Rosamond , I spotted a dust devil breaking off and situated myself down wind of same. There were clouds running down Highway 58 towards Barstow for about 15 miles. I had called Joshua Control to see if 2515 was “hot or cold” that day and had mixed messages. My plan originally called for me to run down the southern boundary of Edwards to the Ord Mountains-when a cloud appeared east of me in that vicinity it was off to the races. I had not been able to see the cumi development thru the haze until I was east of Highway 14. Over the southern entrance Edwards the clouds stopped and did not start for another 15 miles or so. 5 miles north of El Mirage I was on glide to the clouds and getting low. I was able to connect west of Helendale. The hole time I was crossing the Antelope Valley Hammer kept coming over the radio with these low altitude figures but still right on my tail! At Helendale the next shear line started. (We had flown the first 100 miles in 3 hours which is fast). At this point, and with the clouds lined up on the Ords, that we started to make time. I left Helendale with 10k and just headed for the clouds. Robert came over the radio stating that he was climbing thru 14k. I thought “this guy is going to over fly me!” I was able to go to go to cloud base on the Ords and it was off to the races. There was great development running due east along Highway 40-I wasn’t going to make the same mistake twice and headed northeast to the clouds that were forming between Highway 15 and Highway 40. It wasn’t well defines lift but just wispy clouds that were forming in front of me. I was above these railroad tracks. Up ahead was the town of Cima which looked like the last populated area. At approximately 6 p.m. I took off my sunglasses and continued eastward. I wasn’t climbing but just kept bouncing along downwind- I was surprised that the desert was still working. With no real civilization in sight I set my gps for Primm. The needle immediately swung 90 degrees to my left indicating that Primm was 20 miles to my right. I was now at Nipton at the 235 mile mark at 9500’ with the options of continuing to glide straight ahead uphill into an area where I did not see any roads which certainly led to a retrieval hassle-we had people that had been in the truck all day. They were in Baker and I had no radio contact with them. I had given some thought to landing at Nipton but finally decide to go on the 20 mile glide to Primm. The feeling of disappointment was beginning to set in I had flown this far and I was going to make my goal -I couldn’t see Primm in the darkening shadows and felt that would probably land in the dry lake bed south of town. All the time I just kept gliding, gliding, and gliding. When I was about 5 miles away and 2500 agl I felt I would make it. Arriving with 1000’ I circled town looking for a place to land. I had the direction of the wind right and landed on the west side of town just clearing a fence at the last moment. Chase arrived shortly and we were headed for home. 233 miles great circle + 20 miles to Primm for 253 total miles. The flight went as planned and the final glide to Primm was incredible.
Tony Deleo
Wow!
Postby Dean S » Tue Sep 22, 2009 9:32 pm
Now those were some smokin' good flights, and great write-ups too.
Hammer, there's nothing more motivating than a potential 10 mile hike out in 100+ degree heat to help stretch out the final glide - whew! Really nice flying.
Tony, I know you've been itching for the state line for awhile now, and you finally did it - congratulations! But if you were in Primm already couldn't you just extend your final glide to Vegas - c'mon, it's all downhill :)
Postby craig » Wed Sep 23, 2009 8:07 am
Hammer and Diablo, you guys kick ass! Nice flights! Wish I could have been there with you!
craig
Postby NMERider » Wed Sep 23, 2009 10:44 am
Postby tom mayer » Wed Sep 23, 2009 7:28 pm
Holy friging cows, your flights are like a dream we all keep having, the difference being that you woke up and it really happened. Your flights need to be written up in the HG mag. As a member of the elite "gray-panther pilots group", I am especially impressed and proud of the accomplishments of our beloved senior airmen! Way to go you old farts! The kids just don't have the staying power like you guys have! Age is wisdom, wise men fly far! Lead the way Diablo and Hammer, just don't break a hip on landing! Robert, at your age maybe it's a good thing your camelback did'nt work!
"aero-head/lawn dart/strappy"
tom mayer
Postby dteal » Fri Sep 25, 2009 11:58 am
Way cool flights and writeup! I'd like to fly Pine with yall sometime - eager and willing to learn all the techniques. But here's what boggles my mind: after about 90 minutes in the air, I find that my neck hurts and my shoulders are getting pretty sore. At 2 hours, I'm heading for the LZ because I can't hold my head up any longer. How in the world do you guys stay in the air for 5-6 hours? I'd be coming in on final completely limp with my arms at my side and my chin on my chest! My legs would probably be numb too. I'm guessing that it boils down to training, so tonight I'm going to hang a rope in the living room and start watching TV while prone in my harness... :D
DT
dteal
Postby NMERider » Fri Sep 25, 2009 1:06 pm
Postby JimmyZ » Sat Sep 26, 2009 8:54 am
Wow!!! Unbelievable you two. Excellent write up and amazing piloting (as usual). This type of flying is inspiring. Thank you!
Postby Kabir » Sat Oct 03, 2009 2:01 pm
Epic flight
Awesome post
you guys are LEGENDS!
